My Side panel is hot
Go to solution Solved by LogicalDrm,
3 hours ago, Feris said:
close like 2 - 4 cm from GPU to glass
Thats quite a cap. But your temps re normal, and glass gets warm pretty quickly. Its not issue for the glass as you need much higher temps to even warp it.
Not that I know of no. How close is the panel to the gpu?
http://pcpartpicker.com/list/Mf3Zcc My build
R.I.P Donny- Got banned. We will always remember your spamming of "Cancerbooks"
iPhones are like 1 ply toliet paper with a logo slapped on them and years old hardware in them- A Wise Man
https://linustechtips.com/topic/775159-my-side-panel-is-hot/#findComment-9778640
Should be fine as long as it's only warmish, and not scalding hot.
hot air from the GPU hits the case, so it makes sense that the glass gets warm
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/775159-my-side-panel-is-hot/#findComment-9778663
That seems normal. Your temps are fine and there's no need to worry.
https://linustechtips.com/topic/775159-my-side-panel-is-hot/#findComment-9778955
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/775159-my-side-panel-is-hot/#findComment-9779432
