Yes. In computers, most of the connecters will only fit where they are supposed to go. The 3 pin fans work perfectly with a 4 pin slot.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/774713-case-fan-problems/#findComment-9773283
Yup. I did it with my case fans (one is LED) on my Corsair Spec-02 case, and they work fine. If you watch Linus's old build guides, somewhere in there he tells you that it doesn't matter, both 3 and 4 pin fans work with 4 pin headers. But there should only be one pin sticking out after connecting a 3 pin fan.
Mouse: EVGA X17
https://linustechtips.com/topic/774713-case-fan-problems/#findComment-9773297
3 minutes ago, Onepoundlion said:
So I just simply plug it in and leave 2 pin left?
I'm not sure where you got the number 2 from.
2, 3, and 4pin fan headers are backwards compatible.
Moved to Air Cooling.
https://linustechtips.com/topic/774713-case-fan-problems/#findComment-9773301
Thanks for the pic! Should help simplify things for the OP. Cool to know that 4 pin fans work on 3 pin headers as well.
Mouse: EVGA X17
https://linustechtips.com/topic/774713-case-fan-problems/#findComment-9773311
