So after I watched this video by "Designs By IFR", I figured I'd try to do it myself. And I just so happen to have some plexiglass lying about from a previous (failed) project. Now, I've heard many different schools of thought about cutting plexiglass. The most common practices seem to be jigsaw and score-and-snap. If any of you have a preferred way of cutting plexi, feel free to share.
Personally I would rather use a jigsaw since I have less than ideal experience with the other method, but at the same time I cannot warrant I can get a straight cut due to shaky hands.
CPU: Intel Core i5-6600K @ 3,5GHz
-Cooler: Cooler Master Hyper TX3i
Motherboard: MSI B150 PC Mate LGA1151 ATX
Memory: Kingston HyperX Fury 16GB DDR4-2133MHz
Case: Corsair Carbide Air 540 White
-Fans: 3x Corsair HD120 1x Corsair AF140L
GPU: EVGA GeForce GTX 1070 FTW
PSU: Corsair CX600M
Storage: Crucial BX200 240GB SSD (System disk) + Seagate Barracuda 1TB HDD (Storage)
Operating System: Windows 8.1
Partpicker: https://pcpartpicker.com/list/wPhTtJ
https://linustechtips.com/topic/774422-advice-on-cutting-plexiglass/
Jigsaw for faster and rough cuts, score'n'snap for more precise cuts but requires more time and care. I only use snap method for visible pieces where the edge finish is important
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
My favorite is with a table saw as it makes nice straight and clean cuts, you can use a jig saw and smoothen out the cut with a sanding block for gluing or assembly.
I would use a table saw for the reason you stated. However the ones I have access to belong to a carpenter's firm, and I have too much respect for the owners to risk harming their blades. And I'm too much of a cheapskate to buy a tablesaw that I would rarely use.
PSU: Corsair CX600M
^ that's what I usually, consistent pressure is a huge help.
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
I score'n'snap since it provides cleaner edges that need less finishing and is way less messier than a jig or hand saw.
Just be sure to apply uniform pressure on the side that you're snapping from (I place the score right on the edge of a table and use my elbow to apply pressure to the part that is on the table).
Remember to keep the protective film on the plexi so you can avoid unwanted scratches
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
