Arduino Bluetooth Help
Go to solution Solved by dany_boy,
@Amageing, check out the datasheet for all of the AT commands, you should be able to find how to get the mac address there: http://www.electronicaestudio.com/docs/istd016A.pdf
Hi all,
Firstly, I've tried the Arduino forums for help however their account system seems to be a bit broken... (I'm logged in for the account page, I then go to the forum and I'm not logged in, I then log in to find my password is apparently incorrect...)
Anyway that's besides the point. Does anyone know how to get the MAC address of a device connected to a HC-05 bluetooth module on an arduino in C?
This is so I can get the MAC address of the device and authenticate it in the arduino it's self.
Thanks in advance!
Amageing
https://linustechtips.com/topic/774405-arduino-bluetooth-help/
29 minutes ago, Amageing said:
Hi all,
Thanks in advance!
If you don't set the name of the device, the MAC-adress will show up if you look for the Bluetooth-device on your computer/phone.
Running Arch with i3-gaps on a Thinkpad X1 Extreme
Data Science Postgrad
https://linustechtips.com/topic/774405-arduino-bluetooth-help/#findComment-9769581
Thanks for your response Claryn,
I think I might have failed to explain the issue properly.
I meant for the Arduino to read the Phone's MAC Address, not the other way around.
Cheers,
Amageing
https://linustechtips.com/topic/774405-arduino-bluetooth-help/#findComment-9769592
Cheers,
What exactly do you need this for? If it is for authentication, you can simply set a PIN or password on the HC-05 bluetooth module on setup.
https://linustechtips.com/topic/774405-arduino-bluetooth-help/#findComment-9769631
Yes, I'm using the MAC address as a type of two factor authentication along with a physical PIN pad attached to the Arduino. Standard uni project.
Amageing
https://linustechtips.com/topic/774405-arduino-bluetooth-help/#findComment-9769640
Hm. From quickly going over the documentation for the HC-05 and checking online, I can't seem to find any ways you can actually retrieve the MAC-adress of the device that connects to your HC-05. It is weird.
https://linustechtips.com/topic/774405-arduino-bluetooth-help/#findComment-9769647
@W-L, Shouldn't this be in hobby electronics?
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
https://linustechtips.com/topic/774405-arduino-bluetooth-help/#findComment-9769649
My issue as well!
Amageing
https://linustechtips.com/topic/774405-arduino-bluetooth-help/#findComment-9769650
Sorry I didn't realise that was a sub-forum for that!
No worries, a friendly mod will most likely move it there soon enough.
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
https://linustechtips.com/topic/774405-arduino-bluetooth-help/#findComment-9769658
My issue as well!
Are you using any libraries to handle connections etc. with the HC-05? When I did a course at Uni. where we used the HC-05, we used a library from the Institute that made it easier to use the module. We could set UUID of it, have a seperate bluetoothSerialMonitor that we used to send messages between devices etc.
If you are using a library like that, it might have some way of getting the MAC-adress.
https://linustechtips.com/topic/774405-arduino-bluetooth-help/#findComment-9769660
To be honest, I thought I'd try and figure this issue out before attempting to program it.
If there are any libraries you could recommend I'd be very grateful!
Amageing
https://linustechtips.com/topic/774405-arduino-bluetooth-help/#findComment-9769664
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
https://linustechtips.com/topic/774405-arduino-bluetooth-help/#findComment-9769672
Brilliant!
Yeah that shows me what serial commands I need to send to the HC-05 module!
Hopefully I can get it working from here, thanks mate!
Amageing
https://linustechtips.com/topic/774405-arduino-bluetooth-help/#findComment-9769691
