1) how is a loop implemented, even on a high-level language?
2) why are semantic errors more subtle than syntax errors?
3) what is cross-compiling?
4) why is writing assembly code increasingly less common?
5) what does ISA stand for?
6) what is the main difference between 32-bit and 64-bit computers?
7) is HTML a programming language?
8) what is the main difference between C and C++?
9) define an Object Oriented programming language
10) what is the main characteristic of an Object Oriented programming language?
11) briefly describe the Von Neumann architecture
12) what does the Moore's law say?
13) How can the Von Neumann architecture be improved to get better performance?
14) What are the more relevant requirements in a Software Artifact?
15) Why is code reuse beneficial?
16) What is the more relevant security issue of closed source software, firmware and system software in general?
17) What is the main difference among accessing data stored on a tape, on a disk, on a memory card?
18) Would you write the control software for a software plant in assembly code? Discuss benefits and disadvantages? Would you use COBOL? What about SQL?
https://linustechtips.com/topic/774382-computer-questions-help-required/
