Monitor not showing anything
Sorna
So i finished building my pc yesterday and decided to open it for the first time today.
I have plugged my monitor,my keyboard and my mouse to the pc but even though the pc
seems to work fine once i press the button (fans start spinning mobo lights turn on, gpu fans
and rgb open) aswell as my mouse and keyboard open, my monitor stays black and nothing happens.
Is it because it doesnt have windows yet? I just want to go into the BIOS to check it out.
PS. im sure everything is plugged fine, main monitor cable goes to the wall and dvi cable connected
to gpu. Other than that, monitor came with a vga cable but im sure i dont need that
Have you got the correct input selected?
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
check fuse in the monitor cable if its not turning on at all ie no standby light on the monitor check all connections does your mobo have post codes on it (higher end asus boards have 2 8bit displays for them as an example) check input on monitor ie if its on hdmi u anit gona get shit
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
have you installed drivers yet sometimes the computer won't display though GPU without drivers so you need to try with the VGA on the motherboard if that works go install your GPU drivers then reboot and you should be able to use your GPU then
I lurk a lot
Arent i supposed to plug my monitor to my GPU though?
ye but if the pc is not booting that could be y your not getting anything
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
Its the first time i open this pc, i just built it yesterday. In order to install drivers arent i suppoed to see something first?
PS. I havent even installed windows yet
Oh i just realised what you guys are saying.
You are telling me to connect through mobo and when i install gpu drivers i plug it to gpu?
yeah so you need use the motherboard VGA out first to install windows and drivers then you can use your gpu
I lurk a lot
Exactly.
On some cases you can plug everything in to the GPU, sometimes not.
So try the MOBO :)
I just connected the dvi cable to the mobo but still, nothing happens. Not even a
light on the monitor corner where you press the on off thing.
Does it matter which side of the dvi cable goes where? They are both identical
are you sure your monitor is turned on at the wall and on the monitor itself?
I lurk a lot
What do you mean on the wall?
Im just trying to press the on thing which is in the front right corner
of the monitor.
Dont tell me there is another on switch on monitor. That will make me feel so stupid :D
He means at the plug socket on the wall
PC - CPU Ryzen 5 1600 - GPU Power Color Radeon 5700XT- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD   PSU Corsair CX750M - Cooling Stock - Case White NZXT S340
Peripherals - Mouse Logitech G502 Wireless - Keyboard Logitech G915 TKL  Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 & Shifter
WOW i just found it. There was a tiny button on the bottom of the monitor and once i pressed it, it
opened. Thank you guys, i guess i got excited so i didnt realise the monitor features
no problem glad i could help
I lurk a lot
