Need help overclocking rx470
Go to solution Solved by RadiatingLight,
Increase them until the GPU crashes. then lower them a bit.
that's basically all there is to it.
if you feel comfortable, increase the voltage and possibly get an even better OC.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
10 minutes ago, Wongton said:
Thank You!
Also, if it's the single fan powercolor card, it might not be good for overclocking anyway, because it's pretty shit from what I've seen
@deXxterlab97 could tell you all about it, if he wasn't gone. (*Sheds a single tear*)
^ his started doing weird stuff after a week or so. the single fan models are pretty low-quality.
Laptop:
Yeah, I've heard the one i have is pretty bad quality compared to the others. I just want to make the most of what I have for now till I get better parts and if i overclock this gpu, it probably won't be at the max it can go or anything. Thanks!
I'd advise not overvolting
Laptop:
