Hi guys, we need some help. We have finished the build with my friend, but we don't know how to connect the front panel connectors, and as the manual doesn't tell me anything useful, I have turned to you guys. We need to connect HDD_LED, PLED, RESET and PWRSW. We would appreciate any help you can give us, and a colour coded drawing with which pin goes where would be especially helpful. If you need any extra information, ask me!
Thanks
https://linustechtips.com/topic/773897-front-panel-connectors-help/
Power switch goes to power switch connectors, reset switch is connected to reset switch pins, HDD LED + and - go to HDD_LED+ and HDD_LED- respectively, Power LED + and - go to PLED+ and PLED-.
Makes sense, doesn't it?
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
If your case doesn't have + and - on them cause some don't as I've found out, just use your best guess and see if it works. I've never damaged anything plugging a front panel lead in the wrong way.
I spend too much on my PC. Then I spend even more on my Sim Rig. Damn, this stuff's expensive.
if there is no + and - there is uaualy a triangle on the positive side
Yeah thats what I dont know. Ive tried all sorts of combinations, up and down facing text, sideways but it doesnt work, and the manual doesnt help me at all.
