Water cooling
Solved by Energycore,
Just now, nope-not-yes said:well that's another problem (sorry that i am bugging you so much) the thickness would play in to the fact that the defined R5 doesn't have a lot of room at the top between the mobo, so I would doubt i would fit without touching the mobo
Screw it from outside ![]()
No but I see what you mean. EK should have a list of compatible cases for 420mm or 480mm rads, thick or thin.
