So this is gonna be my future build:
https://pcpartpicker.com/list/XVpnJV
However I still need some peripherals since I only have an HDD laying around.
I would like to have a decent keyboard and mice combo since they are good,
cheap and have the same theme. For monitor Id like a decent 1080p and for mouse
pad one of those that fit both the keyboard and mice.
Try to keep cost as low as you can without sacrificing quality
https://linustechtips.com/topic/772596-help-on-peripherals-choise/
red dragon if you wanna go really cheap i used it for like a year i still use the mouse its great and its still going good
https://www.amazon.com/Redragon-S101-Gaming-Keyboard-Centrophorus/dp/B00NLZUM36/ref=sr_1_5?ie=UTF8&qid=1493361683&sr=8-5&keywords=Redragon
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
Keyboard: Turtle Beach IMPACT 500 Wired Standard Keyboard  ($49.95 @ Amazon)
Mouse: Logitech G502 Wired Optical Mouse  ($59.99 @ Amazon)
Total: $109.94
Generated by PCPartPicker 2017-04-28 02:48 EDT-0400
or this for lower budget
Keyboard: Cooler Master Lite L Wired Gaming Keyboard w/Optical Mouse  ($49.99 @ Amazon)
Total: $49.99
Generated by PCPartPicker 2017-04-28 02:50 EDT-0400
$73 23" IPS 75Hz 1080p Freesync Monitor.
$47 RGB Mechanical Keyboard + RGB PMW3320 sensor mouse. Motospeed is the OEM for Finalmouse, Aukey, and Dream Machines; their peripherals are good quality.
$4.60 60x30cm Mouse Mat (promocode TWITTER). Alternatively, any old mouse mat will do; virtually all of them are good quality and the only realistic issue is texture. Since you're not looking for a specific coating, just get a cheap one on Amazon.
That mouse uses an office sensor (it will spin out if you use low DPI and will interpolate if you use high DPI). The keyboard is just standard membrane. Why get that when Logitech sells basic keyboards and mice that perform just as well for half the price?
