I am building another computer on the cheap (mostly used parts) and the motherboard of choice is an older TYAN S7012 (S7012GM4NR) which will house 2 Intel Xeon x5675 CPU's.  I will start with simple fan cooling and maybe later, just for kicks, I may try to water cool it. Would like some recomendations on the tower case for this.  Generally, one that has filters to keep dust out.
https://linustechtips.com/topic/772498-case-for-a-s7012/
3 minutes ago, TheCatShuriken said:
Honestly, its mostly an aesthetic thing. I like white/silver, but its up to you. Pcpartpickers compatibility filters might help ya out here.
I never find that site useful and doing a search it does not even list the parts. lol
https://linustechtips.com/topic/772498-case-for-a-s7012/#findComment-9748357
Just now, TheCatShuriken said:
Weird lmao. Its pretty good for new builds IMO, lifesaver for me. Might wanna measure out ya parts and find a case to fit those dimensions.
Part are not yet ordered, was hoping to have some insight 1st.  I've done my research and I know all the "guts" (inner workings) going inside my box, I just need to pick out the box.  lol   The motherboard was usually installed in servers, but this particular board could be installed in tower servers as well.  The idea is to find the correct tower ATX or E-ATX.
https://linustechtips.com/topic/772498-case-for-a-s7012/#findComment-9748377
Well try finding the dimensions online. Amazon tech specs might help ya out.
https://linustechtips.com/topic/772498-case-for-a-s7012/#findComment-9748379
That I do have
Forgot to ask, Amazon Tech Specs? A Google Search only brings up the tech specs of a kindle.  lol  I doubt that is what you meant.
Sorry lol, I meant when you scroll down on an amazon page and it will list dimensions, etc. Also Amazon seems to be down for me, you getting the same thing?
https://linustechtips.com/topic/772498-case-for-a-s7012/#findComment-9748413
Amazon is up, but Tom's Hardware is down.  Which is how I stumbled onto here.  lol
https://linustechtips.com/topic/772498-case-for-a-s7012/#findComment-9748417
Weird lol. Anyway, this sites pretty great. Try E-ATX searches on pcpartpicker, a 12x13 mobo is e-atx. Might want to double check though, but here. https://pcpartpicker.com/products/case/#f=3&sort=a8&page=1
https://linustechtips.com/topic/772498-case-for-a-s7012/#findComment-9748423
Thank you.  :)   I was not sure if I actually needed a full tower and now I know.  ;)
Now the search continues to one that will allow me to perhaps add water cooling later but also will include air filters to avoid dust.
https://linustechtips.com/topic/772498-case-for-a-s7012/#findComment-9748453
Ah man. I dont know much about water cooling. If your going to invest in water cooling in the far future, I would recommend just buying a case then (prices will go down too). Thats what I`m doing if and when I get water cooling. Thats my two cents. Glad I helped!
https://linustechtips.com/topic/772498-case-for-a-s7012/#findComment-9748456
Yeah, that's an SSI EEB board, the same form factor as my motherboard (In description).
Finding a case for it is a royal pain in the arse as there aren't that many, and any that exist are large,bulky, and expensive. I got a super cheap rack mounted server for $200 that came with 12 500GB hard drives, so I put it in that, it's just super inconvenient moving it around while I'm still at college. So your choices are basically a rack mounted server case, designated intel case, or something like this:
https://www.amazon.com/Phanteks-Enthoo-Chassis-PH-ES614P-TG-Titanium/dp/B00YCX0XR6/ref=sr_1_2?ie=UTF8&qid=1493592394&sr=8-2&keywords=ssi+eeb+case
All of which are large.
COMPUTER: Mobile Battlestation  |  CPU: INTEL I7-8700k |  Motherboard: Asus z370-i Strix Gaming  | GPU: EVGA GTX 1080 FTW ACX 3.0 | Cooler: Scythe Big Shuriken 2 Rev. b |  PSU: Corsair SF600 | HDD: Samsung 860 evo 1tb
https://linustechtips.com/topic/772498-case-for-a-s7012/#findComment-9761670
8 minutes ago, GOD666 said:
Just a final follow-up on the case I believe I have settled on will be a Corsair Graphite Series 780T Full Tower PC Case
Yeah, that's compatible.
https://linustechtips.com/topic/772498-case-for-a-s7012/#findComment-9761677
