Ok, so every time I make a topic, I need answers or opinions right? I won't be 100% sure about what to choose or something. Often I would be like 60-40 and I just want opions. But every.single.time I just ignore all the answers I got if they are against for example the hardware or what I would prefer. Im not even sure if I'm looking for opions anymore, or conformation? I will kind of make my decision in my mind, but then not know the decision I made? Idk. I know this probably sounds pretty stupid but I just wanted to see if anyone here do the same as me :P?
CPU: I5-7600k  MOBO: ASUS Z270G Gaming  GPU: EVGA GTX 1060 3GB FTW+  RAM: Corsair Vengeance LED DDR4 2133mMHz  CASE: Corsair Air 240 Black  COOLER: Corsair H100I v2  SSD: Samsung 960 EVO 250GB  https://pcpartpicker.com/b/h8HhP6
https://linustechtips.com/topic/772424-my-problem-with-forums/
Just keep asking. Even if you don't choose based on the opinions you get, it can help others if they see it.
https://linustechtips.com/topic/772424-my-problem-with-forums/#findComment-9747506
This is actually a known fallacy called 'Confirmation Bias'. The fact your able to identify your guilty of it, hopfully means you can conciously attempt to avoid doing it. Force yourself to read counter points and the like, try hard to really weigh the pro and cons of each side in your head so your sure you are making the correct choice.
Processor: Ryzen 5950x GPU: RTX 3080  Mobo: X570 Aorus Pro RAM: 32GB DDR4 3200Mhz CPU Cooler: Noctua NH-D15
https://linustechtips.com/topic/772424-my-problem-with-forums/#findComment-9747527
Omfg you sniped the hell put of me xD
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/772424-my-problem-with-forums/#findComment-9747532
When i need emotional advice, if we can resonate each other, that will be great. The key point is that i actually already have a decision in my mind, i only accept what i expect to hear, if they have different opinion, i will just think they don't know my situation deeply.
https://linustechtips.com/topic/772424-my-problem-with-forums/#findComment-9749338
On 4/27/2017 at 3:02 PM, AmazingRez97 said:
This is a tech forum
you dont say?
On 4/27/2017 at 3:03 PM, Oshino Shinobu said:
It's a good way to confirm what you want to get. If you're pretty much 50/50 on something, flip a coin. If the option it lands on disappoints you, you've worked out what you really wanted.
exactly!
On 4/27/2017 at 4:34 PM, yathis said:
The thing with forums is
The answers to your questions have already been asked 1000 times.
Humans are just lazy as fuck.
why try and search for the answer and question when you can just ask it? Its easier to ask.
exactly how i feel ..
https://linustechtips.com/topic/772424-my-problem-with-forums/#findComment-9749929
