Excel help
Go to solution Solved by TheRedViper,
11 minutes ago, straight_stewie said:
What SIN function are you looking for?
Nevermind, thx for helping though. Got it to work
=3*SIN(4*PI()*B39+PI()/2)
I have some timestamps that I want in a grid and apply those to a parameter of an electrical sinus function that would be the second column. However the SIN function that excel offers is not the one im looking for (SIN(insert rad/180)).
The timestamps will basically replace the t in the equation
When i tried this it gave me a value error: 3*SIN(4*3.1416*B38(which is the first time cell)+3.1416/2)
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
https://linustechtips.com/topic/772119-excel-help/
The one from the first picture. Its a sinus with angular speed and phase vector
https://linustechtips.com/topic/772119-excel-help/#findComment-9744042
https://linustechtips.com/topic/772119-excel-help/#findComment-9744064
