It seems as if my XFX RS RX480 is running hot, it's at 100% load when I play games, which are set on max settings 1080p. (DOOM and R6Siege for example) Im getting temps between 86-89 but never 90 degrees. I have what I believe to be ample cooling, Corsair 270R Case with two intake fans and an exhaust fan.
All setting on the card are stock, haven't tweaked with anything or played around with settings, newest drivers installed to the best of my knowledge.
Any thoughts or solutions to this?
All input is greatly appreciated.
CPU: Intel Core i7 8700k 3.7Ghz MOBO: AsRock Z370 Extreme4
RAM: Corsair Vengeance (4x4) Storage: Crucial MX300 275Gb | WD Blue 1Tb
GPU: XFX RS RX480 8Gb Case: Corsair 270R PSU: Seasonic Focus+ 750w
Monitors: HP 22cwa | BenQ BL2420PT  Cans: ATH-M50x
https://linustechtips.com/topic/772088-rx-480-running-hot/
Oh.. I have one of these on order.. :(
edit: oh phew I'm getting a 470 Rs still hope it's not the same issues
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743466
The card performs wonderful when it comes to performance in game, and XFX is a notable brand, I'm sure its just a ME problem and won't be a YOU problem lol
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743471
Lol yea I hope not, I'm getting 470 Rs aswell so yea fingers crossed. Not sure how you'd go about fixing it. Maybe try different drivers?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743480
Could be, maybe changing the voltage or something, it could be where I have my PC setup, no idea yet. I'm going to try moving it tonight, I would like to get low to sub 80 degree temps.
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743487
I mean if its not overclocked it shouldn't be pulling any xtra voltage. Youv check the gpu fans are spinning properly and have checked the fan curve is good? You could always reapply the thermal paste which is most likely the problem if the fans are spinning fine and the voltages are stock.
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743495
No not pulling extra voltage, but maybe under-volting it a little would bring temps down as a short term fix, the fan curve is good to the best of my knowledge and both fans are spinning.. although you're making me second guess myself. I'll be doing another round of double checks when I get home lol
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743503
I just thought about the fact that they're "swappable fans" so I might try taking them out, cleaning the contacts, at reinstalling them to see if that helps. Maybe one or both aren't getting good connections.
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743520
if they spin it doesn't matter just check the thermal compound on the processor because that could be the reason the heat isn't being dissipated correctly
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743534
Yep good idea. Sucks having to resort to thermal paste replacement but yea if nothing else works either rma it or reapply the paste
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743536
Yeah that'll be my last resort, I'll exhaust all other options first lol.
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743540
the thing is if fans are spinning they are not the problem you could try using fan curves
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743547
My only point was that if their connection for some reason isn't clean enough then maybe they aren't getting the full power thats being sent, either way, I'll go through the list when I get home, fans working properly, fan curve, computer placement, etc and see where it leaves me.
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743558
Well according to some Redditors the XFX RS is a pretty hot card. YMMV but you might just have to deal with it
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743622
I have this exact card. Mine is oc and doesn't have temps near this. I'm running at max temp 76c and fans at 82%
But I do have more exhaust fans and intake fans on my setup. I have 3 140mm intake fans on the front, 2 120mm exhast fans on top, 1 120mm exhaust fan on the rear, and my psu is flipped to act as an exhaust for the system as well. My case fans don't even go above 60% during heavy gaming loads or bench marking.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743732
Hmmm.. interesting, this could mean that the location I have my pc is trapping too much of the exhaust heat, ill run some tests after moving it somewhere else.
Good to know thank you.
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743740
Yeah. My pc is on my desk with no restrictions on air flow.
Current Build
AMD Ryzen 2600
Stock cooler
1tb SKHynix m.2
WD 1TB HDD
Phantek fans
Phanteks P400TG
Laptop
Ryzen 7 5800h
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743747
Try with side panel off
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9743793
I've read in the past a few ppl experience high temps with the XFX RS model so it could be the model/sample (although others with same model may have differing experience). But originally when the RX 480's came out AMD released a driver fix to resolve some concerns with potential over draw from the pcie slot. Might help in your situation to limit power draw and bring temps down. Here is an expert from the AMD release:
"Separately, we’ve also included an option to reduce total power with minimal performance impact. Users will find this as the “compatibility” UI toggle in the Global Settings menu of Radeon Settings. This toggle is “off” by default."
Also you could investigate Wattman where you can monitor temps and undervolt manually====> "Open up AMD’s Radeon Settings app and click the Gaming tab, then Global Settings, and finally the Global WattMan tab."
I guess if the card is getting 100% usage and not throttling then undervolting is not necessary but it might be worthwhile trying to turn the compatibility UI toggle 'on'.
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9744058
Oh Also I think with wattman (which is integrated into the AMD Crimson Driver) you can set a temperature limiter so the card doesn't go over set a temp (but i assume it will throttle down?? i dunno). I don't have an AMD card yet so cant check. But here is a guide to Wattman: http://www.pcworld.com/article/3094984/components-graphics/how-to-use-amds-wattman-the-powerful-new-overclocking-tool-for-radeon-graphics-cards.html
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9744129
@RS2007GOD @MagicSun @Shiv78 @Zusafek @Colin Donoghue
I confirmed it was the poor placement of my PC, too much hot air was getting trapped and not enough outside airflow, the card is now running around 80 degrees, thanks for all the input!
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9744179
Glad to hear it's resolved.
Current Build
AMD Ryzen 2600
Stock cooler
1tb SKHynix m.2
WD 1TB HDD
Phantek fans
Phanteks P400TG
Laptop
Ryzen 7 5800h
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/772088-rx-480-running-hot/#findComment-9745352
