Cryorig H7 vs CM MasterAir Pro 4
Gmanliving
Hi all,
I am about to buy a new cooler for my second system and want a second opinion.
Since I live in the middle of no-where, the H7 costs $76 and the MasterAir Pro 4 costs $62.
I was slightly leaning towards the Pro 4 because of better build and aesthetics. But it looks like H7 is better on cooling performance but has more plastic parts such as the top of the heatsink.
Thoughts?
Are you referring to the C7 or H7? The title of your thread doesn't match your post.
Why are you looking at these coolers in particular?
Sorry, meant the H7. These are the only two coolers other than the 212 Evo at my local shop so...
They're similar. If you're not sure, just go for the cheaper one.
