I'd get used RAM and SSD. Those things don't suffer too much from being used (well, maybe the SSD does somewhat).
CPU R7 3800X    Motherboard Asus Prime X370 Pro  RAM  24GB Corsair LPX 3000 (at 2933Mhz)    GPU EVGA GeForce RTX 3070 XC3 SC  Case Phanteks Enthoo Pro M
Storage 1 x 1TB m.2 (Windows), 1x 500GB SSD (Linux Mint), 1x 4TB SSD (for data Samsung 870) PSU Corsair RM1000  Cooling deepcool ak620(? probably)
Synology NAS 2 x 8TB
https://linustechtips.com/topic/770880-ryzen-1600-upgrade-help/#findComment-9729342
@rvmva Sorry could only do in USD. That is about the cheapest you can get whilst ensuring quality.
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  ($218.98 @ NCIX US)
Motherboard: ASRock AB350 Pro4 ATX AM4 Motherboard  ($89.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 8GB (1 x 8GB) DDR4-2666 Memory  ($54.99 @ Newegg)
Storage: SK hynix SL308 120GB 2.5" Solid State Drive  ($49.33 @ OutletPC)
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Total: $460.78
Generated by PCPartPicker 2017-04-24 05:59 EDT-0400
https://linustechtips.com/topic/770880-ryzen-1600-upgrade-help/#findComment-9729348
Total: $460.78
Any ideal speed for ram? or 2666 is oaky
https://linustechtips.com/topic/770880-ryzen-1600-upgrade-help/#findComment-9729501
3000 ideally but the biggest % gain over 2133 is 2666. This means the difference between 2133 and 2666 is bigger than 2666 and 3000. I hope I have explained clearly :)
https://linustechtips.com/topic/770880-ryzen-1600-upgrade-help/#findComment-9729503
The SSD is known to be terrible. I would stretch for the Sandisk Ultra II but at the very minimum, get the Kingston UV400.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/770880-ryzen-1600-upgrade-help/#findComment-9729526
7 minutes ago, rvmva said:
hey any difference between AB350 and B350?
no B350 is the chipset the rest is just manufacturer naming. You can get the gigabyte if you prefer, I just like the AsRock.
https://linustechtips.com/topic/770880-ryzen-1600-upgrade-help/#findComment-9729727
