Fans for Antec P183 with ASUS PRIME X370-PRO
Solved by W-L,
4 hours ago, iowyn said:Hey W-L, thanks for the welcome and details! I figured there is a simple solution but couldn't find the answers myself, though I didn't look into build guides or anything but wanted to check here since I figured there'd be a reliable answer here, which! you've supplied, so thanks again, I'll start my research now.
It's 4 fans off two MB points, so it should be fine for the 1A limit.
Yes that won't be a problem, something like this will work.
https://www.amazon.com/SilverStone-Technology-Sleeved-Splitter-CPF01/dp/B00B46XKKQ
