like PCPartPicker lets you check compatibility,is there some way to virtually put my list together so i dont spend money and fuck up something?
  • CPU
    Ryzen 5 1500X
  • Motherboard
    ASUS Prime B350-Plus
  • RAM
    1x8gb Corsair Vengeance LPX
  • GPU
    PowerColor Red Devil RX 580 8gb
  • Case
    Phanteks Eclipse P400s
  • Storage
    Samsung 960 Evo 250 gb
  • PSU
    EVGA SuperNOVA 650W G3 80+ Gold
  • Display(s)
    AOC G2460PF
  • Cooling
    AMD Wraith Spire
  • Keyboard
    Corsair K70 Rapidfire
  • Mouse
    Logitech G502 Proteus Spectrum
https://linustechtips.com/topic/769877-virtual-build/
What are you worried about?
PCpartpicker checks all the electrical compatibility, so all you need to check is GPU length and CPU cooler compatibility, which should be easy to do by looking at the manufacturers website. nothing really special.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/769877-virtual-build/#findComment-9718951
ive repeatedly checked my builds specs and it says everythings ok butt ive never built a computer before so im not trying to mess up by not having some part of putting a different part in the wrong direction or not having good airflow and burning my rig to the ground
  • CPU
    Ryzen 5 1500X
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    AOC G2460PF
  • Cooling
    AMD Wraith Spire
  • Keyboard
  • Mouse
https://linustechtips.com/topic/769877-virtual-build/#findComment-9718958
Nah that part will be fine.
almost all connectors are keyed (the important ones definitely are, like motherboard power, and PCIe power, and SATA, etc.) so they don't fit into the wrong places.
you're really overthinking this IMO.
only really important thing to check is that when installing the CPU, the gold triangle matches up with the triangle on the motherboard. that's the most complicated installation.
Laptop:
https://linustechtips.com/topic/769877-virtual-build/#findComment-9718965
