MOSspring Cable
Go to solution Solved by Drake10114,
9 minutes ago, AlphaGamer46 said:
Hi.
1. It appears that the cable supports Quick Charge, however, I am not entirely sure. You might need to snoop around some reviews or the manufacturer's website.
2. I've never seen them before, but looking at them for the first time, they look cool. Personally, I'm that kind of guy who likes to stick with the cables made for my device, but if you want something way more rugged than the Samsung cables (which are pretty crappy at times) it's definitely worth a look. I would check eBay, as you might be able to get a better deal, as some of the cables appeared to be a bit pricy for Micro USB cables.
Awesome, yeah was hoping someone would know, since the 1 on amazon blatantly says "NOT FOR IPHONE", so I'm assuming yes..., but I'll for sure check some reviews out.
I would stay with my old 1, but the housing by the end is badly damaged, and sometimes hisses at me.. usually I can move it around to trigger the fast charging, but couldn't get it to fast charge anymore, Figure'd with the spring, it shouldn't break, and dat lifetime warranty is nice.
Since idk exactly where to place this, figure'd I'd put this here, so feel free to move it if I was wrong.
My current cable for my Galaxy S6 decided to pretty much give up on me last night, so I've decided to get one of those MOSspring Cables  My questions are:
1. Can I utilize the quick charge feature of my phone, or am I better off getting another samsung cable? (Basically does the cable support quick charging?)
2. Are they as awesome as they appear to be?
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
https://linustechtips.com/topic/769574-mosspring-cable/
Hi.
2017 Gaming PC
Excellent value machine, keeps me going.
CPU: Intel Core i5-6600K | GPU: Nvidia GeForce GTX 1080 8GB | RAM: 16GB DDR4 | Motherboard: MSI Z170A XPOWER GAMING TITANIUM
PSU: Casecom 600W PSU | Case: Corsair Graphite 230T | SSD: Samsung 850 EVO 250GB | HDD: 3TB WD Blue
Dell XPS 15 9560
Beautiful laptop, in a stunning form factor.
CPU: Intel Core i7-7700HQ | GPU: Intel HD Graphics 630/Nvidia GeForce GTX 1050 (not mobile, full GPU) | RAM: 16GB DDR4 | SSD: 512GB SK Hynix SSD
Display: 4K IPS 100% Adobe RGB Touch Panel | I/O: Two USB 3.0 with PowerShare, HDMI, 3.5mm Headphone Jack, SD Card Slot, and Thunderbolt 3 USB-C
Samsung Galaxy S8 64GB | Samsung Galaxy Tab S2 9.7 32GB
https://linustechtips.com/topic/769574-mosspring-cable/#findComment-9714880
Hi.
https://linustechtips.com/topic/769574-mosspring-cable/#findComment-9714898
Nvm, contacted their live chat, and he was able to help me out w/ my 1st question.
https://linustechtips.com/topic/769574-mosspring-cable/#findComment-9714972
