Capacitors don't need heat-sinking
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
https://linustechtips.com/topic/769533-heat-pad-not-touching/#findComment-9714368
Just now, Adarsh Singh said:
I'm taking of that heat conductive pad just above the capacitor, if it is there it should touch it.
Maybe..
Again capacitors don't need to be attached to a heat-sink, they (in theory) don dissipate any heat. In practice, because of ESR and reactance (during transients) they will dissipate some heat, however it is such a small amount that you might as well assume they don't.
TLDR it's fine as it is
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
https://linustechtips.com/topic/769533-heat-pad-not-touching/#findComment-9714380
Everything conducting electricity releases heat (2nd law of thermodynamics). You are right however that the head release is negligible.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/769533-heat-pad-not-touching/#findComment-9714553
How did you extrapolate that from the fact that entropy cannot decrease? genuinely curious BTW
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
https://linustechtips.com/topic/769533-heat-pad-not-touching/#findComment-9714567
The second law of thermodynamics more or less says that all energy degrades continuously into entropy (until equilibrium). In a closed loop system, like a circuit, energy level remains constant throughout the system. As all energy continuously degrades to entropy (heat) it would make sense that all electrical energy (and kinetic energy of the moving electrons) would also degrade into heat. I could be way off base here, that has just been my understanding of it.
https://linustechtips.com/topic/769533-heat-pad-not-touching/#findComment-9714931
Not to brag or anything, but I'm currently studying thermodynamics in physics in college. And I do think you are way off :P. Heat is energy, and Heat != entropy. Entropy = disorder.
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
https://linustechtips.com/topic/769533-heat-pad-not-touching/#findComment-9714951
Ahh, a bio teacher of mine used them almost interchangeably, so i assumed that entropy WAS essentially heat. Either way, terminology aside, I think i am still somewhat on track with my explanation. The kinetic energy at the very least should cause heat due to friction.
https://linustechtips.com/topic/769533-heat-pad-not-touching/#findComment-9714983
Either way it's not a thermal pad. At most it's the standard foam they use for insulation. This should only make contact, if need be.
https://linustechtips.com/topic/769533-heat-pad-not-touching/#findComment-9715007
