Hey, so Ive got a dual bios 480, and i figured id try turning it into a 580. Its currently overvolted and overclocked to 1410 with only 80 mv extra, so i know it can take it. But when i downloaded the ati winflash and got the 580 bios, it says systemID mismatch. Could this be because the bios was 8gb and my card is 4gb? Thanks in advance
13700k, 3070, 32GB@3200
https://linustechtips.com/topic/769420-help-flashing-bios/
Yes. Your card needs to be the 8gb version. You will brick the board if you try it with that BIOS.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/769420-help-flashing-bios/#findComment-9713189
ah, ok. do you know any sites that have the 4gb bios? also wouldnt it just destroy the bios that its on?
https://linustechtips.com/topic/769420-help-flashing-bios/#findComment-9713195
I dont know of them sorry. I dont have any AMD cards. There are multiple posts regarding this topic here in LTT though.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/769420-help-flashing-bios/#findComment-9713202
