in-case wireless transmitter??
Go to solution Solved by AvocadosGuac,
1 minute ago, Jrock said:
Your pc doesnt support what?
oh shit...
At PCI speeds, you're better off getting a USB wifi adapter like this
https://www.amazon.com/EDUP-Wireless-External-OS10-6-10-12-Installation/dp/B00KV9TQXM/ref=sr_1_6?s=electronics&ie=UTF8&qid=1492739408&sr=1-6&keywords=usb+wifi
I have no idea what the thing that I want is called... I want something I can plug into a PCI port and have it transmit a WIFI signal. From my searching, This is what I found. If you have a suggestion, PLEASE leave it below
SPECS:
GPU: gtx 1060
CPU: i5 6500k
MOBO: H110M-A
HDD: 2tb seagate 64 cache 72000rpm
RAM: ddr4 2133 16gb
https://linustechtips.com/topic/769374-in-case-wireless-transmitter/
Any PCI wireless card can be setup to transmit a wifi signal. USB dongles are also cheaper and can transmit it too
I use NETSH from cmd. just google "netsh wifi sharing" or somethin similar.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
Yeah my pc doesn't support that. I went cheap on the mobo, it doesnt have many features built in.
(I'm assuming it's the mobo that has to support it?)
oh shit...
yo 300mbps is good enough for me thanks lol
