hi I'm new to the pc game I would like to know what kind of overclock I could get  on the setup I'm using and how well this will perform I will be using it for playing world of tanks and playing war thunder and maybe using It to play Xbox play anywhere titles
Gigabyte 990x SLI gaming
AMD FX6300 Black Edition
Cooler Master Hyper 212 EVO
Aero cool 500w 12cm PSU
Gigabyte RX 460 OC 4GB GDDR5
Patriot viper 3 2x4GB 2400mhz
https://linustechtips.com/topic/769350-oc-help/
Just now, Damascus said:
I'm pretty sure thats streaming so your hardware matters very little when using it
I didn't know like I said I'm new pc gaming spent 10 years on Xbox can I expect to play my world of tanks and warthunder on some decent graphics I know its dependent on the GPU just the one I listed is all I can afford
https://linustechtips.com/topic/769350-oc-help/#findComment-9712347
Have you bought the system yet?
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/769350-oc-help/#findComment-9712349
1 minute ago, bigkev1815 said:
its all bought just put it all together yesterday shall I just crank it up and see what it can handle and just dial it back till I get it stable
Other way around,  go up in slow increments, doing a 15-30 minute stability test each time
https://linustechtips.com/topic/769350-oc-help/#findComment-9712364
2 minutes ago, Damascus said:
Similar GPU, same PSU
Same same, but in another language
couldn't understand the language but it looked like it was all cranked up I was looking at the gtx 1050 but couldn't justify the £25 difference as the rx 460 I have seemed to have better stats thanks a lot your help is much appreciated
https://linustechtips.com/topic/769350-oc-help/#findComment-9712381
Yeah, RX 460  is very similar to a 1050, you made a pretty good move there.
https://linustechtips.com/topic/769350-oc-help/#findComment-9712389
