nocuta Air cooling
Solved by shairene,
17 minutes ago, Zomicron said:I think they are about the same. I think it will depend more on the airflow of your case. Would it be better to have air flowing across the motherboard, or down at it? If you have a typical tower style case with air flowing from front to back/up then it would probably be better to have the D9L. Regardless both are good coolers and if you can successfully OC with satisfactory temps than I see no reason to change your decision. I personally Would just call it good and keep the NH-L12.
I have the air 240 so there is a good airflow so I can add fans so there will be pleanty of air
