I recently get a new build, and here are some specs:
CPU: i7 6700k
cooler: corsair h105
motherboard: asus z170 pro gaming
ram: patriot viper elite 2666mhz
evga supernova 850g2
evga gtx 1080 SC
i'm trying to OC the cpu to 4.7ghz, is 1.325V sounds good for the voltage for gaming and everyday use? Probably will use for like 12+ hours on average per day.
I'm also going to OC the gpu, what are some successful and safe results? +200/+500 for clock and memory?
https://linustechtips.com/topic/768572-overclocking-help/
1.325 should be fine as long as your temps are ok and it is stable. I cant get stable 4.7ghz even on 1.4V :(
+200 is quite a lot, start lower and increase it if it is stable
5900X
MSI MEG X570 Unify
32GB DDR4 Corsair Vengeance
RTX 3080
Dark Base Pro 900
Corsair RM1000i
https://linustechtips.com/topic/768572-overclocking-help/#findComment-9703319
