Here is $1000,
I only have a couple requirements and needs
1. Case has to be a Crystal Series 570X RGB ATX Mid-Tower Case w/Corsair SP120 RGB 3-Pack w/Controller 52.0 CFM 120mm Fans ($230 combined)
2. Should be able to overclock, ( I want to try to overclock a PC, figured now would be a good time)
3. Doesn't need a big storage drive ( I already have two, 1 Tb, usb's which will be permanently stuck, used to store files)
4. Should be able to play some games like Minecraft, etc at  +40 fps
5. Doesn't need a lot of random access memory ( if the build impresses the client, he is willing to spend more on these parts)
6. Monitor can only reach 1080p
The main aims of the build are
- To play average games
- To open files/games/videos quickly
- To render hour long videos
- To look cool af (btw, i haven't researched into water cooling at all, is it possible?)
This is a start-ish ( though its too expensive)
https://pcpartpicker.com/list/HjCXNN
EDIT: If you can, please modify the build in the link to $1000. I don't really know where to cheap out on.
https://linustechtips.com/topic/767217-1000-for-a-pc-build/
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  ($218.39 @ NCIX US)
Motherboard: MSI B350 TOMAHAWK ATX AM4 Motherboard  ($97.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($119.88 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($99.88 @ OutletPC)
Video Card: Asus Radeon RX 480 8GB ROG STRIX Video Card  ($239.99 @ Amazon)
Case: Corsair Crystal 570X RGB ATX Mid Tower Case  ($167.99 @ B&H)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.79 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($88.58 @ OutletPC)
Case Fan: Corsair SP120 RGB 3-Pack w/Controller 52.0 CFM  120mm Fans  ($62.99 @ Amazon)
Total: $1175.47
Generated by PCPartPicker 2017-04-16 07:17 EDT-0400
https://linustechtips.com/topic/767217-1000-for-a-pc-build/#findComment-9688266
Don't buy a GTX 970 for 369$. You can get a GTX 1070 for about the same price.
I would recommend an  AMD Ryzen 7 1700 (or 1600 if the 1700 is too expesnsive) if he wants to render hour long videos. Keep in mind that you dont need a X370 motherboard to overclock Ryzen, B350 allows overclocking as well.
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/767217-1000-for-a-pc-build/#findComment-9688267
Total: $1175.47
Would there be a need for a radiator?
https://linustechtips.com/topic/767217-1000-for-a-pc-build/#findComment-9688277
https://pcpartpicker.com/list/Q2GTRG
$200 over budget, but a solid setup, with most of your previous choices
CPU: I7 4790K(4.6@1.252v)                               Case: Fractal Design Define R5 Windowed(Black)           Cooler: CM 212 EVO + NF F12 iPPC
RAM: HyperX Fury 1600MHZ CL10 2x4GB      Storage: Samsung 850 EVO(250GB) + WD Red(2TB)      PSU: Corsair RM750 (and no, it hasn't blown up!)
MoBo: Asus Maximus VII Ranger                      Graphics: MSI GTX 970 TwinFrozr (1494MHZ Core)       OS: Windows 10 Enterprise
https://linustechtips.com/topic/767217-1000-for-a-pc-build/#findComment-9688315
look, i get that you want the pc to look good, but a case that takes up almost 20% of your budget isn't a good solution. look at something like the DIYPC J21-W or depcool dukase instead.
https://linustechtips.com/topic/767217-1000-for-a-pc-build/#findComment-9688316
try something like this and get OS from reddit for $20-30.
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  ($28.98 @ NCIX US)
Motherboard: ASRock AB350M-HDV Micro ATX AM4 Motherboard  ($69.99 @ SuperBiiz)
Memory: ADATA XPG Z1 16GB (2 x 8GB) DDR4-2400 Memory  ($86.48 @ NCIX US)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($80.49 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.69 @ OutletPC)
Video Card: Zotac GeForce GTX 1070 8GB Mini Video Card  ($359.99 @ Newegg)
Case: DIYPC DIY-J21-W ATX Mid Tower Case  ($44.97 @ Newegg)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($44.89 @ Newegg)
Total: $981.87
Generated by PCPartPicker 2017-04-16 07:49 EDT-0400
https://linustechtips.com/topic/767217-1000-for-a-pc-build/#findComment-9688330
1.- If you're going to overclock, don't get a budget cooler, or at least get cryorig h7 and not the cheapest on the market. I recommend to get aio like h100i.
2.- If you're going to purchase a 6th gen, you don't have to get Z270 board, Z170 will work fine (also, that's a very expensive unnecessary motherboard, MSI Z170A M5 has literally same things for less money)
3.- GTX 970, please... You can get it from 190$ on eBay... For 370$, you could get r9 fury x or gtx 1070 (which is 33%/55% better)
4.- If i were you, i'd buy windows 10 from kinguin which is abour 30$ but it's optional since some people don't trust on these sites.
Total: $981.87
but he won't be able to oc with that mobo...
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/767217-1000-for-a-pc-build/#findComment-9688343
what are you talking about? all b350 motherboards will overclock.
https://linustechtips.com/topic/767217-1000-for-a-pc-build/#findComment-9688345
I think you are confusing B350 with B150/B250 from Intel, which cant OC.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/767217-1000-for-a-pc-build/#findComment-9688357
ah sorry, i though that was A300/A320, mb
https://linustechtips.com/topic/767217-1000-for-a-pc-build/#findComment-9688378
53 minutes ago, Glass said:
Here is $1000
Intel Build, it's $50 over budget but very hard to cut back anymore if you want a decent overclockable system.
Quote
PCPartPicker part list: https://pcpartpicker.com/list/ycs4hq
Price breakdown by merchant: https://pcpartpicker.com/list/ycs4hq/by_merchant/
CPU: Intel Core i5-7600K 3.8GHz Quad-Core Processor  ($234.43 @ OutletPC)
Motherboard: MSI Z270-A PRO ATX LGA1151 Motherboard  ($114.89 @ OutletPC)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory  ($63.15 @ Amazon)
Video Card: Asus Radeon RX 470 4GB STRIX Video Card  ($168.99 @ SuperBiiz)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($72.88 @ OutletPC)
Operating System: Microsoft Windows 10 Pro OEM 64-bit  ($34.00)
Total: $1048.18
Generated by PCPartPicker 2017-04-16 08:15 EDT-0400
AMD Build, 6Cores/12Threads, fits within your budget and personally think it's a better build if your gonna be doing video rendering. If it's my money, I would personally go with this build.
Quote
PCPartPicker part list: https://pcpartpicker.com/list/GQs4hq
Price breakdown by merchant: https://pcpartpicker.com/list/GQs4hq/by_merchant/
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($73.59 @ Amazon)
Total: $996.69
Generated by PCPartPicker 2017-04-16 08:12 EDT-0400
The RX470 performs about the same as a GTX970, but uses less power, half the price and you can use freesync if you get a freesync monitor in the future. Also get your windows 10 from kinguin, it's $34 for Win10 Pro.
https://linustechtips.com/topic/767217-1000-for-a-pc-build/#findComment-9688392
PCPartPicker part list: https://pcpartpicker.com/list/kKTc7h
Price breakdown by merchant: https://pcpartpicker.com/list/kKTc7h/by_merchant/
Case: Corsair Crystal 460X RGB ATX Mid Tower Case  ($129.99 @ B&H)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($62.99 @ Amazon)
Total: $1033.49
Its like the same case but smaller
the graphics card is RGB i believe
Generated by PCPartPicker 2017-04-16 08:22 EDT-0400
https://linustechtips.com/topic/767217-1000-for-a-pc-build/#findComment-9688403
