29 minutes ago, apaar123 said:
Which is the best option for colored liquid coolant or dye so that I have least/no amount of blockage or other problems ?
Currently i find that the Mayhems Pastel to be very good. Running past a year of use rn so should probably check it again.
I'm using the Pastel Orange and haven't had any bad luck with it.
You could always go distilled + dye since you can control intensity of the colour.
https://linustechtips.com/topic/766933-coloured-coolant/#findComment-9685063
Which one will be a better option?
https://linustechtips.com/topic/766933-coloured-coolant/#findComment-9685104
I stick with Pastel (or concentrate) tbh. Comes with the anti corrosive stuff pre-mixed but there isn't really much of a difference between distilled + dyed and concentrate solutions going staining or clogging.
https://linustechtips.com/topic/766933-coloured-coolant/#findComment-9685170
3 hours ago, apaar123 said:
Will they clog?
No, they shouldn't clog.
How fast does the coolant run out?
It doesn't run out. But you should renew your coolant at least once every 6 months to a year.
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/766933-coloured-coolant/#findComment-9686198
The fluid should not get hot enough to cause the water/fluid to evaporate, therefore shouldn't run out but as stated above it is advised to change it every 6 months to a year to reduce any problems such as growth, corrosion, etc.
The fluid may look like the level is reducing through the first month but this is due to air pockets moving around and out of the system.
Desktop: Cooler Master MasterCase 5 | i7 6700k @4.7GHz 1.3v | Custom EKWB soft-tubing loop (CPU + GPU) (2x 240mm Alphacool rads)| Zotac GTX 1080 Founder Edition | Asus Maximus VIII Hero Motherboard | Samsung 850 EVO 512GB SSD | 4TB Seagate HDD | 2TB Seagate HDD | EVGA SuperNova G2 750 | Acer Predator XB271HK | https://uk.pcpartpicker.com/list/xzjRHN
https://linustechtips.com/topic/766933-coloured-coolant/#findComment-9688223
