so i ran firestrike today and my graphics scor dropped from 37k to 32k, any ideas why
i have uninstalled geforce experiance as that has been a problem before but it did not help
something is stopping my top card from being fully utilised any ideas on how i can fix this or what is causeing it please
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/766150-low-gpu-usage/
Are you actually monitoring GPU usage when this occurs? If it's still hitting 99% usage, check clock speeds on both the Core, and Memory.
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676255
Drivers possibly?
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676256
Yes I am monitoring them and the top card just drops to 86 percent
and in gaming top card drops to 80 percent and causes huge frame loss
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676267
2 minutes ago, lilbman said:
Drivers possibly?
I have reinstalled drivers
and still the same
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676268
Temperatures then?
                    PSU Tier List: https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
CPU Celeron n2830 - GPU Integrated - RAM 1x4GB DDR3 1333MHz - Storage 750 GB 5400RPM HDD
                                                Operating System Windows 10 Home
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676269
Just now, WAR Corporation said:
Temperatures then?
temps are in the 50s
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676272
What's your PSU? and GPU?
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676278
its normaly nvdia share that does this, but i comepletly uninstalled it
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676281
My best guess for now would be to do a fresh install of your drivers, and if that doesn't fix it and you've updated them recently, revert back to the older version.
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676282
sli 980tis
supernova 850
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676283
i did a clean install il try some olderr drivers now but they were workling fine before my new motherboard
could that be the issue ?
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676288
I doubt it, but I suppose it's possible - if somehow the motherboard is not allowing the bandwidth that's being requested(even if it should be there).
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676291
Hmm weird
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676294
gona disable sli and try it
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676296
Go for it.
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676302
Running at 99 percent usage without sli
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676306
Re-enable SLI and see if the situation repeats. Do you have other bridges that you can use?
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676316
Sli disables graphics score was only 19000 I think it's usually around 21k
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676325
Did clock speeds change from your typical?
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676326
No clock speeds are fine
re enabled sli now and it's still the same
it's like something is utalising my card
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676342
Could it be my base clock oc effecting it ?
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676354
Would appear it was the base clock being at 102 just dropped it back to 100 and ran test and got 33k not oced just running test again with oc applied
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676397
31 minutes ago, lilbman said:
Drivers possibly?
28 minutes ago, WAR Corporation said:
Temperatures then?
Thanks for the quick responses, godly mentioning clock speed changes got me thinking about jays 2 cents trying to base clock a 4790k and getting funky gpu results
so yeah rolled it back to 100 and pushed the multiplier up instead and got a 36.8k firestrike score (due to running a slightly lower clock and memory than usual for thermal reasons
thank you tho
and add base clock to the diagnostics list if anyone else has an issue :)
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676428
Also with the base clock oc in gpuz it read as pcie 2.0 but now it's 3.0 so maby it was choking the bandwidth too
also (1600)
https://linustechtips.com/topic/766150-low-gpu-usage/#findComment-9676472
