I have a build thread going, where I will be putting in a custom loop into my Define Nano S. I was planning on a GTX 1080, but I'm not sure I can justify the cost. The custom loop is already really expensive, especially since I'm using stainless steel tubing, but at the same time I'm not sure if it's worth liquid cooling the 1070.
I need some advice on where I should head with this build, I will be using the PC heavily, especially through the next few years during my stay at university. A powerful system will help a lot not only when I'm bored and want to game but when I'm doing school stuff like CAD, since I will be an engineering major. Just not sure if it's worth the $550 price tag on the 1080 (cheapest I can find right now, including tax) and if the extra performance will equate to longevity.
This is a list of the other hardware, to give you an idea of what I'm working with. I don't really care much about CPU performance, the only thing I worry about with that is whether or not it will bottleneck the GPU. Hence the Xeon.
Xeon E3-1231v3 (need to buy, currently have an i5 4570)
AsRock B85M-ITX (have it)
AData Premier Pro 16GB DDR3-1600 (have it)
Samsung 850 EVO 500GB (have it)
WD Blue 1TB (need to buy, maybe a 2TB, just need some extra storage space)
Define Nano S (have it)
EVGA BQ 650W (have it)
I play on a VG248QE 144Hz monitor. I would ideally like to crank the settings to max and not drop below 60-70FPS. I am also planning on using a 42" or so 1080p TV as a secondary monitor to play from afar. So I will for sure be playing at 1080p.
Just need some general direction on where to go. I don't want to spend a whole f*ck ton of money, but I still want the system to last for a while without needing another upgrade. The custom loop I can justify only because for one, it looks hella nice, it makes the system run a lot cooler and quieter (since it will be in my dorm room while I sleep), and I get hella bragging rights for having a stainless steel tubed liquid cooling loop. xD
https://linustechtips.com/topic/765591-build-advice/
1070 = bragging rights, 1080 = bigger bragging rights, 1080 Ti = more bigger bragging rights!
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/765591-build-advice/#findComment-9669559
