Just now, Droidbot said:
Yep, that's normal.
Okay, so there is likely no bottleneck?
Only thing i feel is the escape, lag and 1 frame drop + increase at times.
Else when I start the game before we can "do our mission" i can get a small lag, but never when i play and repair the generators :)
Yeah, that's just the game being badly optimized. I've had it happen on both my system and a friend's system (he has a 6700k)
idk
Ah okay, thanks a lot! :) but are there some games I should find a bottleneck in?
Yes, I have the same setup and I've seen slight bottlenecks in GTAV with MSAA disabled, but that's really it.
idk
Thanks a lot sir! So I'll not be upgrading my build for now i guess, I'll just swap the thermalpaste and pump it up to 4,2 :P
