Monitor Mount + Ikea Desk
Sdot
Just wanted your opinion guys on if this is a good idea or a bad idea.
This is the mount I want to purchase goo.gl/wiI5nP
This is the desk I have goo.gl/8VuNxD
Product description
Top: Fiberboard, Acrylic paint,
Frame: Particleboard, ABS plastic
Filling material: Paper
Bottom: Fiberboard
Do you guys think this desk will be able to hold up 4 monitors? I don't want to get the stand because the clamp just looks a lot cleaner and gives me a bit more desk space. Thank you in advance for your opinions. Also, I never know if I am posting in the correct place, sorry.
It might, but you need some counter weight on the front.
Mainline: MacBook Air M1 Display(s): Acer K272HUL; VIOTEK - GNV32DB Keyboard/Mouse: Logitech M720/K780 Sound: AirPods 3 Operating System: MacOS Phone: iPhone 13 Pro (Graphite)
nah man that shit is made of compressed cheese gratings, don't put anything heavy on it that you don't want broken
Home PC:
CPU: i7 4790s ~ Motherboard: Asus B85M-E ~ RAM: 32GB Ballistix Sport DDR3 1666 ~ GPU: Sapphire R9 390 Nitro ~ Case: Corsair Carbide Spec-03 ~ Storage: Kingston Predator 240GB   PCIE M.2 Boot, 2TB HDD, 3x 480GB SATA SSD's in RAID 0 ~ PSU:    Corsair CX600
Display(s): Asus PB287Q , Generic Samsung 1080p 22" ~ Cooling: Arctic T3 Air Cooler, All case fans replaced with Noctua NF-B9 Redux's ~ Keyboard: Logitech G810 Orion ~ Mouse: Cheap Microsoft Wired (i like it) ~ Sound: Radial Pro USB DAC into 250w Powered Speakers ~ Operating System: Windows 10 Enterprise x64
Work PC:
CPU: Intel Xeon E3 1275 v3 ~ Motherboard: Asrock E3C226D2I ~ RAM: 16GB DDR3 ~ GPU: GTX 460 ~ Case: Silverstone SG05 ~ Storage: 512GB SATA SSD ~ Displays: 3x1080p 24" mix and matched Dell monitors plus a 10" 1080p lilliput monitor above ~ Operating System: Windows 10 Enterprise x64
i considered cheaping out on a desk but so glad i didnt, i got a free 6 foot pine desk from office clearance, i have 2 monitors, a mixer and my rig on it and probably wouldnt put any more on, and that's an inch of solid pine.
Ive seen too many decent battlestations sitting on horseshit grade desks and it just scares me man. same logic as why u don't get a cheap PSU. Literally all your expensive stuff depends on it.
Home PC:
Work PC:
Fellow shitty Ikea table user here, I wouldn't try it.
Currently have a hole in mine because I set my PC down a little too hard and one of the feet went through the desk :P
I'm a fucking AMD kawaii weeaboo desu I have seen the light
i5 6600k EVGA 980 FTW Z170A PC Mate 1TB WD Blue240GB SSD Plus NZXT S340 | EVGA 600b  | Dedotated 8GB
