Hello all lam from Australia l have a corsair 760t case with window side but l have to put it back on the floor. What lam try to ask is what is the best thing to do keep my case with all the lights in it and known l will not be seeing them on again or buy one with on window if so what is the best also must have room for 2x1080 video cards
https://linustechtips.com/topic/764430-best-case/
May I be correct in questing as to why you are required to situate your chassis on the floor? You should not be needing to remove any of the lightings/illuminations within your case if they are mounted internally. Your current chassis does already has a windowed side panel so I do not understand as to why you want another, although that is probably my fault sorry xD If you have carpet, or pets, you always should elevate your PC off of the floor to prevent easy dust accumulation.
Kind regards,
-EnergyEclipse
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/764430-best-case/#findComment-9656547
