DEEPCOOL GENOME II
Go to solution Solved by W-L,
5 minutes ago, skkler said:
So if u look at the front u see the tubing spiral up. Inwanna add another on in there but on a different loop so i cn run 2 colors
It would be more of a matter of being able to fit two shorter reservoirs with custom mounts and a separate rad/pump unit. Possible but a fair bit of work, also just to note the original rad that came with the loop is aluminum so you will need a mixed metal compatible fluid as they probably provided originally.
Just a rather curious question, I have already googled it but didnt find anything, I recently got a DEEPCOOL GENOME II from a friend who just dint like the idea of water cooling so he just boguht a new one. and i was curious would it be possible to remove he helix water tubing and replace it with different tubing? if so how would i do it?
https://linustechtips.com/topic/764294-deepcool-genome-ii/
It can be taken out the reservoir he doesn't like it, what were you thinking of replacing it with exactly?
https://linustechtips.com/topic/764294-deepcool-genome-ii/#findComment-9655266
https://linustechtips.com/topic/764294-deepcool-genome-ii/#findComment-9655705
