Hello,
I found this coolant from feser one "Ultra pure water" and it says on the website im buying it from that the pH is 2-3. Isn't that eh... bad?
EDIT: This is taken from the site:
"Feser Aqua has to first of all passed through the reverse osmosis system, and shortly after this into the downstreamed De-Ionized system. The PH-Value is 2.0 - 3.0 and lies in the acid ph-range."
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/76418-watercooling-coolant-question/
That must be a mistake. Pure water is slightly acidic, but not that much.
Here's Speicaltech's listing: http://www.specialtech.co.uk/spshop/customer/Feser-Aqua-Ultra-Pure-Water-1-Litre-pid-4573.html
pH 5.5 - 6.5. That's the range I would expect.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
