https://pcpartpicker.com/list/mMK39W
I got a Strix Z270-E and Strix 1060 6gb as a gift from my friends. And I bought an 7600k from January when there was a sale. Also Ill be taking 2x8 DDR4-2400 ram from my uncle.
I dont really have a budget, and I'm using this to mainly play games and do a bit of editing/rendering.
Two things im not sure about are:
CPU Cooler: I'm not sure if I need an AIO, if its overkill I think I can switch it to an air cooler. But which air cooler? Also, Im thinking of overclocking.
Storage: Is it a good idea to invest into an nvme m.2? And since there are 2.5" mounts on the case, is it okay to use a 2.5" harddisk? or should I just stick with 3.5"?
https://linustechtips.com/topic/763993-cpu-coolers-and-storage/
enermax T50 is pretty good for $50-55, on par with 240mm AIOs for less.
if you're just gaming, you won't notice a difference between nvme and a normal sata drive. get the hynix sl308 instead.
https://linustechtips.com/topic/763993-cpu-coolers-and-storage/#findComment-9651807
NVME isn't useful for normal workloads/things.
2.5 inch hard drives are fine, but there's no reason to get them, because they're just more expensive per GB than a normal 3.5 inch drive, and you have enough room.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/763993-cpu-coolers-and-storage/#findComment-9651818
Ahh thanks for the info. Do you have any suggestion on what SSD to get?
https://linustechtips.com/topic/763993-cpu-coolers-and-storage/#findComment-9651823
Thanks man Ill check them out.
https://linustechtips.com/topic/763993-cpu-coolers-and-storage/#findComment-9651835
Just not sandisk SSD Plus.
CS1311 is pretty good if you're going for a budget SSD
all Samsung SSDs are incredible
Laptop:
https://linustechtips.com/topic/763993-cpu-coolers-and-storage/#findComment-9651840
