Move the insert for who knows what down a slot so you have two of the pcie brackets open directly next to eachother, then just like how the current one is installed.
https://linustechtips.com/topic/763713-graphics-card-size-issue/#findComment-9648769
how long is it?
i am going to make a dangerous assumption it is around 300mm long (the only length 4+ cases I have)
it should fit
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/763713-graphics-card-size-issue/#findComment-9648772
What's the cable in the second PCI bracket? PSU power cord?
Move it to another slot.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/763713-graphics-card-size-issue/#findComment-9648778
9 minutes ago, Dave8798 said:
Yes, a GTX 1050 will fit in your system, however I'd be safe and get a single fan version of the 1050 and not a dual fan so that you have a smaller card. EVGA, MSI, Gigabyte, etc all have single fan versions of the 1050.
Oh, yeah, also move that power cable PCI extension down a slot.
https://linustechtips.com/topic/763713-graphics-card-size-issue/#findComment-9648779
Actually it's an old and big VGA connector which I think is required by the old montors and all I removed it and now there is a free bracket and idk what to do because my GPU (zotac gtx 1050 is having a single bracket.
https://linustechtips.com/topic/763713-graphics-card-size-issue/#findComment-9648940
I'm buying the gtx 1050 of zotac which has a single slot and as well as single fan pretty fast. But im left with one big bracket empty beacuse I removed that cable below the GPU any suggestions what should I do?
https://linustechtips.com/topic/763713-graphics-card-size-issue/#findComment-9648959
53 minutes ago, Dave8798 said:
Didn't get you. :/
If you're getting the single slot card, then nevermind.
https://linustechtips.com/topic/763713-graphics-card-size-issue/#findComment-9649213
