Hello,im new to this forum and i need help for old hardware, i have a compaq presario 4016 (not hp compaq) and the motherboard kind of posts ,it starts to post but there are garbage letters all over the screen,and i want to know what is the problem, i cleaned the mobo and case, and i have a psu question that it has a 6 pin power connector for cpu ( not gpu neither my psu has 6 pin power for cpu, and my psu has a solid 24 pin power and the mobo needs 20 pin so can i plug the 4 pin cpu power to  6 pin cpu power and 24 pin mobo power to 20 pin power (the psu is out of a dell, a ac bel psu)
PC Specs:Custom Built PC
CPU:AMD Ryzen 3 1200 GPU:Zotac GeForce GTX 1050 TI Mini RAM:Corsair Vengence 2400 MHz DDR4 Motherboard:ASUS Prime B350M-A AM4 Motherboard Case:Corsair 100R PSU:Corsair VS450
Laptop Specs:Acer TravelMate 8472
CPU:Intel Core i5 560M Memory:2GB DDR3 CPU:Intel HD Graphics Case:Its a Laptop Motherboard:Laptop Motherboard
https://linustechtips.com/topic/763534-old-hardware-help/
On 4/7/2017 at 8:53 PM, LabRat said:
NO!
what do you mean
https://linustechtips.com/topic/763534-old-hardware-help/#findComment-9647304
