OverHeating
Go to solution Solved by WhiteWolf117,
22 minutes ago, xDylanio said:
Are you stressing using prime 95?
I was using blender to test. I found the problem though for some reason the termal paste wasn't working, It was still sticky after 3 months of use so i use replaced and it fixed it
1My I7 4790k is overheating at stock on a h100i. it hovers around 37c idle (14c ambient) and goes to 90c at 100% in about 10 seconds, then  when I turn off the stress test it goes back to 37 in like 5 seconds
|| CPU Intel Core i7‑4790K 4.9 Ghz || Motherboard MSI Z97S SLI Krait Edition || RAM corsair vengeance pro 4x8gb 2400mhz || GPU msi msi twin frozr gtx 1080 8g sli x2 || Case nzxt phantom 410 || Cooling corsair h100i ||
https://linustechtips.com/topic/763527-overheating/
https://linustechtips.com/topic/763527-overheating/#findComment-9647046
What are your temps now?
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
https://linustechtips.com/topic/763527-overheating/#findComment-9647056
20s idle mid 50s underload and high 70s overclocked
https://linustechtips.com/topic/763527-overheating/#findComment-9647065
