Alright so I just bought a new monitor along with all the necessary stuff to build my own pc and while i'm waiting on the last couple parts I thought I would use the new monitor for my chromebook. So I use an HDMI to hook up my chromebook to the monitor and it works great looks clear but after anywhere form 5 to 20 minutes the monitor screen goes gray and when i open my chromebook back up nothing is wrong but the monito stays grey. So I restart the chromebook and then i works again. repeat. repeat. So is it a problem with the hdmi 2.0, my chromebook, or the monitor because if it is the monitor I need to return it while i can. NOTE: I thought since chromebooks aren't really meant for high usage that I was possibly overloading it because I have and rgb keyboard, rgb mouse , a mic, and headset hooked up to it all at once plus docking into the monitor. Now I tried just using the keyboard and mouse and it still did.
https://linustechtips.com/topic/763498-need-help-please/
