I have been having this problem with my graphics card ive been playing games and my computer has been shutting off and forcing me to press the restart button on my case and this happens in Warframe and the fuzzy doughnut of death aka furmark. i've got a log of GPU-Z's readings up to when it crashed and i've put most of it into a sheet that you can find Here:https://docs.google.com/spreadsheets/d/1pvoT_-U7Abq1zz5EAHBC2VutzWGlzF-AnFVdft2YqMU/edit?usp=sharing i think its an overheating problem because before it turns off you can see the clock speed etc. go down but its only happened the last couple of days
CPU: https://ark.intel.com/products/65702/Intel-Core-i5-3570-Processor-6M-Cache-up-to-3_80-GHz
GPU: https://www.techpowerup.com/gpudb/b2443/xfx-double-d-r9-280x
PSU: Corsair H1000I
MOBO: Gigabyte GA-B75M-D3H Revision Unknown
https://linustechtips.com/topic/762907-forced-shutdown-unknown-cause/
9 minutes ago, AndersT2 said:
I juse a progam called Real Temp, gives temp on every core
Sensor Movement Test:
Movement Core 0: 20. Core 1: 19. Core 2: 17. Core 3: 18.
CPU Cooldown Test
Test 1: CPU Load 100%, Average Distance to TJ Max: 1.0, 0.0, 1.0, 1.0.
Test 2: CPU Load 100%, Average Distance to TJ Max: 1.8, 0.6, 3.0, 3.3
Test 3: CPU Load 100%, Average Distance to TJ Max: 2.3, 1.2, 4.2, 4.0
Test 4: CPU Load 100%, Average Distance to TJ Max: 4.3, 3.6, 6.3, 5.6
Test 5: CPU Load 100%, Average Distance to TJ Max: 6.8, 5.0, 8.0, 7.6
if TJ to max is 1 degree, you have a overheating problem With the CPU. chech if the cooler is mounted correctly, and if the goop is good enough
Sorry for the few off Capital letters in my posts, it does it on its own when I Write in English, since my OS is in another Language. It's annoying.
hey sorry for the late reply i was running around town looking for an air compressor or can but anyways. i opened up my case and i remembered that i havent cleaned it out for about 7-8 months and my air cooler was completely full of dust and other crap so i cleaned all of it out and now going to run furmark and the prime95 tests again see how it fairs
Might be that when it cools down, it speedsup again, and then gets warm, and slows down, and does it over and over again.
But seems it might be a little fast to run up and down.
But do remember that Furmark puts extra stress on the parts that you don't get from normal use, so it should have that much to impact normal use.
