possible to fix dead ram
Go to solution Solved by doomsriker,
Try removing your ram and blowing out the slots with compressed air (can be purchased on Amazon), than carefully clean your ram's connectors with 90% isopropyl alcohol  and let it sit for a couple hours to dry. Then put the ram back in. If that doesn't work, you are pretty much out of luck.
So i was swaping hard drives when i unplugged the pc i did not notice it was in sleep so i booted up and i was able to use it for a bit before i got a critical ram error and bluescreen i then remember i turned on the computer 2 weeks ago and never turned it off is there a way to fix the ram or is it just dead i dont really care if its dead i just wanna know if it is possible to fix
https://linustechtips.com/topic/762557-possible-to-fix-dead-ram/
Unplugging the RAM while it's in use is pretty bad, but I don't think it has the possibility to ruin the RAM.
Try it in a different PC and run memtest 86.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/762557-possible-to-fix-dead-ram/#findComment-9635858
It wasnt unplugged whule running it had old data from the old os which was never turned off and i didny notice until i switched drives
https://linustechtips.com/topic/762557-possible-to-fix-dead-ram/#findComment-9635879
OS data isn't stored on your RAM, it's stored on your HDD.
What exactly did you remove, and what state was the system in?
Laptop:
https://linustechtips.com/topic/762557-possible-to-fix-dead-ram/#findComment-9635883
https://linustechtips.com/topic/762557-possible-to-fix-dead-ram/#findComment-9635888
 What i mean is the system was in sleep when i unplugged instead of off so it had all the tabs and whatever was open still there
https://linustechtips.com/topic/762557-possible-to-fix-dead-ram/#findComment-9635962
I guess so, but that's more program data than OS data.
anyway, I'd suggest a re-install of windows, and see if that works. if not, try it on a different system, and if that doesn't work, you have some dead RAM.
Laptop:
https://linustechtips.com/topic/762557-possible-to-fix-dead-ram/#findComment-9635966
