what power supply?
Go to solution Solved by Guest,
Evga g2/g3
Corsair rmi/rmx
i need a quiet power supply for this rig that im building
Obsidian Series® 900D Super Tower Case
Intel® Core™ Processor i7-7700K 4.20GHZ 8MB Intel Smart Cache
NZXT Kraken X61 240mm RGB CPU Liquid Cooling System w/ Copper Cold
Plate - Extreme Cooling Performance
Windows 10 Pro (64-bit Edition)
ASUS STRIX RAID PRO 7.1 PCIe Gaming Sound Card
motherboard-ASUS TUF Z270 MARK 2 ATX w/ USB 3.1, 3 PCIe x16, 3 PCIe
x1, 6 SATA3, 2 M.2 SATA/PCIe
MSI Radeon RX 480 Gaming X 8GB GDDR5 Video Card [dual card]
VENGEANCE® RGB 32GB (4 x 8GB) DDR4 DRAM 2666MHz C16 Memory Kit
1TB Western Digital Caviar Blue SATA-III 6.0Gb/s 7200 RPM HDD
then im gonna put these fans in it Corsair Air Series AF120 Quiet Edition
https://linustechtips.com/topic/762465-what-power-supply/
First I must ask:
Why no SSD
Why giant case with one GPU and no watercooling setup
Why a 7700K and a 480
Then I'm going to suggest you completely redo your build with this in mind.
https://linustechtips.com/topic/762465-what-power-supply/#findComment-9635486
