Hi guys, I have 3 displays hooked up 1 is DVI, 1 is DP to DVI and 1 is HDMI but for some reason the HDMI is running at 59 hertz instead of 60 and when I unplug one of the other displays I get the option to switch the HDMI display to 60.
I would like to fix this as it fiddles with games that dont support 59 and I would like to keep the HDMI monitor in the middle as it is the largest.
Thanks!
https://linustechtips.com/topic/761914-3-display-problem/
Go into Nvidia or AMD Control Panel and manually set the resolution and refresh rate.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/761914-3-display-problem/#findComment-9627677
It most likely is correct. The GPU will handle programs correctly. Try setting V-Sync on and seeing what frame-rate it gives you.
https://linustechtips.com/topic/761914-3-display-problem/#findComment-9627866
