Just now, leonfagan71 said:
What operating system are they using?
If Windows, you would probably have to modify the chip on the USB to execute code.
However, if you had access to the machine, you could just create a scheduled task to run a batch file or something.
Windows 7
https://linustechtips.com/topic/761874-flash-drive-mount-script/#findComment-9627102
Just now, kemit_frog said:
I do not have access to the machine nor admin credentials sadly
Unless autoplay is enabled, you'd have to modify the USB programming.
It's not at all easy and can take a lot of attempts before you eventually get what you want.
https://linustechtips.com/topic/761874-flash-drive-mount-script/#findComment-9627777
