Hello!
I'm looking for a new CPU cooler for my i7-4790k.
I was originally on a Cryorig A40 but its pump failed and there are many prettier coolers on the market and I think an air cooler would be interesting.
I currently have my eyes on the Cryorig R1. However, I don't know where I order Customod from.
http://www.cryorig.com/r1-ultimate_us.php
I'd prefer something pretty.
I also have two Corsair SP120s left over from my CryorigA40.
Thanks!
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/761589-good-air-cooler/
2 minutes ago, ★ Coups ★ said:
Hello!
Thanks!
https://www.alternate.co.uk/Cryorig/Cover-for-R1-Installation-Kit/html/product/1209762
https://skinflint.co.uk/cryorig-customod-for-r1-black-a1531960.html
https://linustechtips.com/topic/761589-good-air-cooler/#findComment-9623491
Just now, deXxterlab97 said:
Thanks!
Why don't they provide these links on their website? Or am I just blind?
https://linustechtips.com/topic/761589-good-air-cooler/#findComment-9623501
2 minutes ago, EnergyEclipse said:
Hello there!
May I recommend of a Cooler Master Master Air 4 CPU Cooler. In particular this CPU Cooler features of a black shroud, covering the topping of the heat sink, thus meaning it shall fit sleekly amongst other components. Furthermore, the included fan is of spectacular qualities being a MasterFan Pro 120 Air Balance, therefore meaning you previous Corsair fans could be relocated elsewhere within your chassis, so I would not imagine it will fail anytime soon unlike your pump.
However, always remember to check chassis height allowance for a CPU Cooler using a larger heat sink, as interference could potentially be met with the side panel, & width with your RAM.
Kind regards,
-EnergyEclipse
Will it be as good at cooling as the Cryorig R1? It looks much smaller.
Also, is it quiet?
https://linustechtips.com/topic/761589-good-air-cooler/#findComment-9623549
9 minutes ago, deXxterlab97 said:
If you want quite get a Dark Rock Pro 3
Air 4 seems ok
cooler-master-masterair-pro-4-cpu-review_30
From what I see, the Cryorig R1 is very close. However, I will check out reviews and such.
Do you know if the Cryorig R1 can support normal fans, such as my Corsair SP120s?
Thanks
https://linustechtips.com/topic/761589-good-air-cooler/#findComment-9623640
Thanks
The DRP3 is much quieter if that's what you're looking for.
Yes, the clips support fans with 120mm mounting holes. SP120's are a downgrade from the stock fans though.
Why not just ask Cryorig for a cooler replacement?
https://linustechtips.com/topic/761589-good-air-cooler/#findComment-9623861
1
Cheers. What could I do with the Sp120s then?
The original broke, and they already sent out a replacement.
I think I could sell the A40 on Ebay. It is RMA'd and pretty much brand new.
Thanks
https://linustechtips.com/topic/761589-good-air-cooler/#findComment-9625877
You could just not use them. I personally have many fans just lying around.
https://linustechtips.com/topic/761589-good-air-cooler/#findComment-9631194
They weren't really used much, and they are premium fans.
https://linustechtips.com/topic/761589-good-air-cooler/#findComment-9638125
If you mean the price then sure, they're premium. SP120's aren't exactly amazing when it comes to performance or acoustics.
https://linustechtips.com/topic/761589-good-air-cooler/#findComment-9641807
