...wats ur budget? and why are you trying to get a laptop.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/760753-next-upgrade-help/#findComment-9614301
1 hour ago, Hari S said:
I was just wondering if there are any durable and long lasting laptops. I game and edit as well as do basic things like email.
Dell 7567.
Laptop Main
https://linustechtips.com/topic/760753-next-upgrade-help/#findComment-9614591
3 hours ago, Hari S said:
it is good but any other because it seems pretty thick
if you think that's thick then you're going to have a hard time finding decent and powerful laptops.
Laptop Main
https://linustechtips.com/topic/760753-next-upgrade-help/#findComment-9618033
2 hours ago, Hari S said:
snip
Ohhhhhhhhhh my bad. If u just want a solid machine, look at the x260s on ThinkPad outlet or eBay refurb. Or t460s
Laptop Main
https://linustechtips.com/topic/760753-next-upgrade-help/#findComment-9619342
