So on my bios it will not let me change the voltage. so i can only get 3.7, when i use overdrive i can get it up to 4.4. The only issue is that when ever i turn my pc back on all the settings are gone. Is there any way for this to save and apply on startup ?
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/760746-overdrive-will-not-save-clock/
On 4/1/2017 at 11:24 PM, killmenow5000 said:
Well it looks like you should be able to change and save your voltage in bios.
Whats stopping you from changing it in bios?
There is no setting in the bios. It says it "automatically" sets the voltage
