Hello, i have a small question to get out of mi mind:
I will set up a network that looks like this:
<Internet> -----(coaxial)----<Modem>----(cat 6) ---- <Router> ----(cat 6) ---- <Switch 10,100,1000BaseT> ----(cat 6) ---- <PC1>, <PC2>, <PC3> .... <PC 20>.
DHCP is provided by the Router.
Every PC is directly conected to the Switch via cat 6 T568B terminal pinout.
cat 6 cable is well under the 100 feet mark, more like 40feet. (i post in feet since i believe you are all americans, if not, i dont need more than 12Metres long cables, the place is kinda small).
My question is:
If i transfer a package between PC1 (gigabit nic) and PC2 (gigabit nic), this will be the path right?: <PC1> ----(cat 6) ---- <switch> ----(cat 6) ---- <PC2>.
I'm afraid i can't tell if the package will be going through the router since that's who provides the DHCP... i strongly believe it won't, and the switch will be doing the hard work of transfering at gigabit speeds.... but can't get this out of my head.
Thanks in advanced!
https://linustechtips.com/topic/760090-a-switch-bandwidth-question/
30 minutes ago, Schakal_No1 said:
only the dhcp will go to the router (and some DNS etc packages), after that everything is handled by the switch.
29 minutes ago, GhzLodur said:
Yes
2 minutes ago, manikyath said:
normally, packets always take the shortest/fastest way possible.
Thanks all of you, i expected such behavior now i can be sure it won't mess with my network desired bandwidth. (The internet connection is utter crap, even a cat 5 could handle it lol)
