https://pcpartpicker.com/list/kC7MKZ
Im planning a LAN party build and would like to know if there's anything wrong with my planning. (Prices are adjusted manually for microcenter and eBay sales.)
My main concerns are with overclockability given the limited airflow. Any suggestions are appreciated.
3600X @ stocke | 5600XT TUF OC @ 1850 | 2x16 + 2x8 RAM 3200 HD | 1tb Samsung 970 EVO Plus | Lian Li 205M | TT Toughpower Grand RGB 850 | throwaway b450 asus mobo | BQ cooler
https://linustechtips.com/topic/759353-suggestions-on-itx-build/
Here is how L9i does on load
noctua_nh_l9i_low_profile_cpu_cooler_review_28
Can reach up to 96 overclocked load according to this page http://www.overclockersclub.com/reviews/noctua_nhl9i/4.htm
https://linustechtips.com/topic/759353-suggestions-on-itx-build/#findComment-9597331
That cooler is barely rated for the processor (Cooler = 95W TDP, CPU = 91W TDP), so you won't be overclocking on that. Noctua has another low-profile cooler that's beefier and you could probably squeeze some overclocking, but it makes working on the system stupidly hard if you ever need to poke at the motherboard again.
https://linustechtips.com/topic/759353-suggestions-on-itx-build/#findComment-9597333
1 minute ago, deXxterlab97 said:
1 minute ago, M.Yurizaki said:
Are there any itx cases that are still small but allow a standard cooler?
https://linustechtips.com/topic/759353-suggestions-on-itx-build/#findComment-9597354
Any of the cube style cases like the Fractal Node 304, Corsair 250D, or Bitfenix Prodigy.
But you may as well go mATX at that point.
https://linustechtips.com/topic/759353-suggestions-on-itx-build/#findComment-9597399
