While gaming, sometimes I will experience micro shutter lags (the GPU usage will drop to 0% at the same time). As a result, gameplay is not smooth. It become even worse when I turned up the video settings. I checked CPU and GPU temperatures and they are perfectly fine. GPU driver updated to latest. Games I played are Dota 2 and CSGO.
Besides, FPS in Dota 2 is unstable. While I was playing with bots, I got around 100 FPS in the beginning. After a few minutes, the FPS will drop to 60-80FPS (without teamfights). FPS even dropped below 60 during teamfights. I play on fastest preset (low settings) and in my opinion, I got a below average FPS.
Specs are in my signature below. Anyone can help?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/759224-anyone-can-help-gpu-issues/
If it starts dropping after a couple minutes, it's some type of throttling. Check that your GPU and i5 are boosting properly via Aida64 or HWmonitor
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
But the temperatures are fine. Maximum 65 for CPU and 60 for GPU.
Desktop specs:
I didnt say thermal throttling did I? I said "some type of throttling" and so go check and see if your GPU clock(s) or your i5 are throttling for some reason.
Oh ok xD
Desktop specs:
53 minutes ago, Aphexxis said:
2.5ghz i5 is not exactly a beast for CSGO, could be the issue.
Turbo boost up to 3.5 (1c), 3.3 (2c) and 3.1 (4c)
Desktop specs:
1 hour ago, vaiwalker said:
could be some background program doing something no? installed or updated anything recently?
I don't have any background programs running. Updated GPU driver recently but no change.
Desktop specs:
Guest
